Статьи : Телевидение / Цифровое ТВ /
DVB. Стандарты и спецификации
Добавлено пользователем administrator 29.01.2013 в 23:20.
REFERENCE NO.TITLE
COOKBOOK
DVB CookDVB BlueBook A020 Rev. 1 (05/00)A guideline for the use of DVB specifications and standards
TRANSMISSION
EN 300 421 V1.1.2 (08/97)Framing structure, channel coding and modulation for 11/12 GHz satellite services
TR 101 198 V1.1.1 (09/97)Implementation of Binary Phase Shift Keying (BPSK) modulation in DVB satellite transmission systems
DVB BlueBook A003 Rev. 1 (05/95)User Requirements for Cable and Satellite delivery of DVB Services, including Comparison with Technical Specification
Draft EN 302 307 V1.1.1 (06/04)Second generation framing structure, channel coding and modulation systems for Broadcasting, Interactive Services, News Gathering and other broadband satellite applications
DVB BlueBook A082 (07/04)Commercial Requirements: Advanced coding and modulation schemes for broadband satellite services
EN 300 429 V1.2.1 (04/98)Framing structure, channel coding and modulation for cable systems
EN 300 473 V1.1.2 (08/97)DVB Satellite Master Antenna Television (SMATV) distribution systems
TS 101 964 V1.1.1 (08/01)Control Channel for SMATV/MATV distribution systems; Baseline Specification
TS 102 252 V1.1.1 (10/03)Guidelines for Implementation and Use of the Control Channel for SMATV/MATV distribution systems
Draft EN 300 744 V1.5.1 (06/04)Framing structure, channel coding and modulation for digital terrestrial television
Draft TR 101 190 V1.2.1Implementation guidelines for DVB terrestrial services; Transmission aspects
DVB BlueBook A004 (03/96)User Requirements for Terrestrial Digital Broadcasting Services
TS 101 191 V1.4.1 (06/04)Mega-frame for Single Frequency Network (SFN) synchronization
Draft EN 302 304 V1.1.1 (06/04)Transmission system for handheld terminals
EN 300 748 V1.1.2 (08/97)Multipoint Video Distribution Systems (MVDS) at 10 GHz and above
EN 300 749 V1.1.2 (08/97)Framing structure, channel coding and modulation for MMDS systems below 10 GHz
EN 301 701 V1.1.1 (08/00)OFDM modulation for microwave digital terrestrial television
EN 301 210 V1.1.1 (02/99)Framing structure, channel coding and modulation for Digital Satellite News Gathering (DSNG) and other contribution applications by satellite
TR 101 221 V1.1.1 (03/99)User guideline for Digital Satellite News Gathering (DSNG) and other contribution applications by satellite
EN 301 222 V1.1.1 (07/99)Co-ordination channels associated with Digital Satellite News Gathering (DSNG)
DVB BlueBook A033 (03/99)DSNG Commercial User Requirements
MULTIPLEXING
EN 300 468 V1.5.1 (06/04)Specification for Service Information (SI) in DVB systems
TR 101 211 V1.6.1 (05/04)Guidelines on implementation and usage of Service Information (SI)
Draft TR 101 162 V1.2.1. (02/01)Allocation of Service Information (SI) codes for DVB systems
EN 300 472 V1.3.1 (05/03)Specification for conveying ITU-R System B Teletext in DVB bitstreams
EN 301 775 V1.2.1 (05/03)Standard for conveying VBI data in DVB bitstreams
Draft EN 301 192 V1.4.1 (06/04)Specification for data broadcasting
TR 101 202 V1.2.1 (01/03)Specification for data broadcasting;Guidelines for the use of EN 301 192
TS 102 006 V1.3.1 (05/04)Specification for System Software Update in DVB Systems
SOURCE CODING
TS 101 154 V1.5.1 (05/04)Implementation guidelines for the use of MPEG-2 Systems, Video and Audio in satellite, cable and terrestrial broadcasting applications
TS 102 154 V1.2.1 (05/04)Implementation Guidelines for the use of MPEG-2 Systems, Video and Audio in Contribution Applications
DVB BlueBook A084 (07/04)Implementation Guidelines for the use of Audio-Visual Content in DVB services delivered over IP (Draft TS 102 005 V1.1.1)
SUBTITLING
EN 300 743 V1.2.1 (10/02)Subtitling systems
INTERACTIVITY
DVB BlueBook A008 (10/95)Commercial Requirements for Asymmetric Interactive Services Supporting Broadcast to the Home with Narrowband Return Channels
ETS 300 802 V1 (11/97)Network-independent protocols for DVB interactive services
TR 101 194 V1.1.1 (06/97)Guidelines for implementation and usage of the specification of network independent protocols for DVB interactive services
ES 200 800 V1.3.1 (11/01)Interaction channel for Cable TV distribution systems (CATV)
TR 101 196 V1.1.1 (12/97)Interaction channel for Cable TV distribution systems (CATV); Guidelines for the use of ETS 300 800
ETS 300 801 V1 (08/97)Interaction channel through Public Switched Telecommunications Network (PSTN)/ Integrated Services Digital Networks (ISDN)
EN 301 193 V1.1.1 (07/98)Interaction channel through the Digital Enhanced Cordless Telecommunications (DECT)
EN 301 199 V1.2.1 (06/99)Interaction channel for Local Multipoint Distribution System (LMDS) distribution systems
TR 101 205 V1.1.2 (07/01)Guidelines for the implementation and usage of the DVB interaction channel for Local Multipoint Distribution System (LMDS) distribution systems
EN 301 195 V1.1.1 (02/99)Interaction channel through the Global System for Mobile Communications (GSM)
TR 101 201 V1.1.1 (10/97)Interaction channel for Satellite Master Antenna TV (SMATV) distribution systems; Guidelines for versions based on satellite and coaxial sections
EN 301 790 V1.3.1 (03/03)Interaction channel for Satellite Distribution Systems
TR 101 790 V1.2.1 (01/03)Guidelines for the Implementation and Usage of the DVB Interaction Channel for Satellite Distribution Systems
Tr101790.V1.2.1.DVB-RCST-MIB (07/03)This is the "DVB Return Channel Satellite Terminal Management Information Base"
EN 301 958 V1.1.1 (03/02)Digital Video Broadcasting (DVB); Specification of interaction channel for digital terrestrial TV including multiple access OFDM
DVB BlueBook A073r1 (07/04)Interaction channel through General Packet Radio System (GPRS)
MHP
ES 201 812 V1.1.1 (12/03)Multimedia Home Platform (MHP) Specification 1.0.3
tam527r31 (JavaDoc1.0.3)JavaDoc for MHP 1.0.3
TS 102 812 V1.2.1 (06/03)Multimedia Home Platform (MHP) Specification 1.1
A066r1 (07/03)MHP Implementation Arrangements and associated agreements
INTERFACING
ETS 300 813 V1 (12/97)DVB Interfaces to Plesiochronous Digital Hierarchy (PDH) networks
ETS 300 814 V1 (03/98)Interfaces to Synchronous Digital Hierarchy (SDH) networks
TR 100 815 V1.1.1 (02/99)Guidelines for the handling of ATM signals in DVB systems
TS 101 224 V1.1.1 (07/98)Home Access Network (HAN) with an active Network Termination (NT)
TS 101 225 V1.1.1 (01/01)In-Home Digital Network (IHDN) Home Local Network (HLN)
DVB BlueBook A029 (05/97)User and Market Requirements for In-Home Digital Networks
R 206 001 V1 (03/97)Guidelines for implementation & use of the Common Interface for DVB Decoder Applications
TS 101 699 V1.1.1 (11/99)Extensions to the Common Interface Specification
TR 101 891 V1.1.1 (01/01)Digital Video Broadcasting (DVB); Professional Interfaces: Guidelines for the implementation and usage of the DVB Asynchronous Serial Interface (ASI)
TS 102 201 V1.1.1 (03/99)Interfaces for DVB-IRDs
A016 Rev. 3 (07/04)Interfaces for DVB-IRD (Draft TS 102 201 V1.2.1)
INTERNET PROTOCOL
TR 102 033 V1.1.1 (04/02)Architectural Framework for the Delivery of DVB-Services over IP-based Networks
DVB BlueBookA086 (07/04)Transport of MPEG-2 based DVB Services over IP based networks (draft TS 102 034 V1.1.1)
A086 — dtd_xsdXML description of DVB BlueBook A086
TS 102 813 V1.1.1 (11/02)IEEE 1394 Home Network Segment
TS 102 814 V1.2.1 (04/03) Ethernet Home Network Segment
DVB BlueBook A079 (04/04) DVB Interim Specification : IP Datacast Baseline Specification, PSI/SI Guidelines for IPDC DVB-T/H Systems
DVB BlueBook A080 (04/04) DVB Interim Specification : IP Datacast Baseline Specification; Specification of Interface I_MT
CONDITIONAL ACCESS
ETR 289 V1 (10/96)Support for use of scrambling and Conditional Access (CA) within digital broadcasting systems
DVB BlueBook A011r1 (06/96)DVB Common Scrambling Algorithm : Distribution Agreements
TS 101 197 V1.2.1 (02/02)DVB SimulCrypt; Part 1: Head-end architecture and synchronization
TS 103 197 V1.3.1 (01/03)Head-end lmplementation of SimulCrypt
DVB BlueBook A045r3 (07/04)Head-end lmplementation of SimulCrypt (draft TS 103 197 V1.4.1)
TR 102 035 V1.1.1 (02/04)Implementation Guidelines of the DVB Simulcrypt Standard
MEASUREMENT
TR 101 290 V1.2.1 (01/01)Measurement guidelines for DVB systems
TR 101 291 V1.1.1 (06/98)Usage of DVB test and measurement signaling channel (PID 0x001D) embedded in an MPEG-2 Transport Stream (TS)
TS 102 032 V1.1.1SNMP MIB for test and measurement applications in DVB systems
v2-tc.myv2-tc.my MIB files containing the definition of "external" object referred in the TR 101 290 MIB.
v2-smi.myv2-smi.my MIB files containing the definition of "external" object referred in the TR 101 290 MIB.
v2-conf.myv2-conf.my MIB files containing the definition of "external" object referred in the TR 101 290 MIB.
7.SYSTEM-MIB.mytext of chapter 7 of the draft TR 102 032 V1.1.1
8.SIGNAL CHARACTERISTICS-MIB.mytext of chapter 8 of the draft TR 102 032 V1.1.1
9.TR101290-MIB.mytext of chapters 9 of the draft TR 102 032 V1.1.1
POLICY STATEMENTS
DVB BlueBook A048 (04/98)DVB response to the Commission Green Paper on the convergence of the Telecommunications, Media and Information Technology sectors and the implication for regulation
DVB BlueBook A002 (11/94)A Fundamental Review of the Policy of European Technical Regulations Applied to the Emerging Digital Broadcasting Technology
DVB BlueBook A006 Rev. 1 (10/95)Recommendations of the European Project Digital Video Broadcasting — Anti-piracy legislation for Digital Video Broadcasting
DVB BlueBook A061 (10/00)Parental Control in a Converged Communications Environment Self Regulation, Technical Devices and Meta-Information
Источник: http://www.broadcasting.ru
→ 20:52 MSK. Воскресенье, 10 декабря 2023 г.
